Got the ceiling transition from double wall in-has a male crimp end, stove receives male , how with no clearance does one slip this in? A slip/adjustable will not make the connection! Whats the trick! Method? Thanks Keith n Kansas
Just what I did! But took a floor/car jack lifted the back up, took the rear legs off, dropped it down till I could slip the pipe in & with two people one jacking & one working the top in then slow lifting with the jack working the bottom in, worked super! Just make sure your stove is well centered (PIPE) & is very close to the length you need! THANKS FOR THE INPUT! Got a nice tight fit with less money for fittings & also a better look! Thanks again! Keith n Kansas
