Need advice for water treatment.
sparke
564
Maine
I am moving and my tank may be shut down for an extended time. Especially if I can not sell my house and end up renting it. Can anyone tell me what to treat the tank with? I am thinking about draining it. That will depend on the status of my home when I move...
What is your tank made from? That might make a big difference.
Assuming that you are shutting down the system and won't be using it, I would think that draining it would be the best bet in general.
An EPDM tank probably wouldn't need much of anything in the way of treatment on an empty tank.
Just guessing, but I'd think a for steel tank your best bet would be to get it as dry as you possibly can, possibly spray the inside with some sort of oil if you can, and then seal it up with a bunch of dessicant crystals inside...
Gooserider
Sparke, where you have a polypropylene liner, I do not think you need to do anything to the water if you leave it filled.
Polypropylene is very inert.
Your PEX HX will be fine also.
Tom
Goose, you are right I will drain it if it is extended time but I hate to do that. Fall is just around the corner ; ) Last year I ran it straight through the summer. This year it will be down for at least 4 months.
Tom, Thanks for the good news!!
If it's a plastic lined tank, I agree, it is pretty much inert, so there isn't a big need to drain it from a harm to the tank standpoint, UNLESS you think there is a risk of it freezing. The other potential issue with an unused tank, is how much "wildlife" might start growing in it, and if so, whether or not the house might start to smell like the "Creature from the Black Lagoon" has moved into the basement...
Gooserider
