Need advice on attaching stove pipe to clay flue pipe
jlouki01
3
Cincinnati, Ohio
I have a mid 80's house with a nicely constructs chimney. Previous owner removed stove, covered pipe coming off chimney.
Chimney is clay lined and in great shape. Has a 8" OD pipe coming off it. Problem is it has an inside diam. of 6 + inches?
Installing a king stove with a 6" pipe.
Need to adapt somehow to this clay flue pipe. I can use a 6x8 adapter fits over the clay pipe perfectly with a little air gap around the sides. Can you tape these up with something?
The connector pipe from the stove goes inside of the pipe. The gap around the connector pipe gets sealed with stove cement.
But first, have the flue cleaned and checked by a professional sweep and ask the sweep about this connection. I am assuming the previous owner did things correctly, but without an eye on the actual installation, it's just advice.
The actual inside diameter is 6.5". The 6x8 fits very snug around the pipe. Could I just seal it up with some stove cement? Seems like that would work pretty well.
You're supposed to slide the 6 inch pipe inside that clay thimble, BOTH of which should be flush with the inner wall of the vertical flue pipe.
