Hi Everyone,
We had a new Avalon Olympic wood stove insert installed last March, following a terrifying chimney fire. We're still learning the art and science of this stove, and now we realize we've made some mistakes.
Primarily, the wood we've been burning wasn't dry enough, so the stove typically doesn't burn above 300-350 - although once or twice we were able to get it up to 400. Now we know we should be closer to 400-500 or more on a regular basis.
We've also been doing the slow overnight burn, which causes creosote to form on the glass in the morning. From now on, we plan on making sure it's burning hotter than that, and/or let it burn out.
We also just switched wood suppliers, and the new wood looks looks really good. And we have an appointment with the chimney sweep late next week.
But we don't know if it's safe to burn in the meantime, and that's where I could really use your help. After the last fire, I am just terrified about the possibility of another one!
So we looked up into the chimney this morning, and there's a fine grey dusty creosote coating the inside, just above the stove. (We can only see about 4' up, because the chimney goes into an angle after that.) Maybe there's a 1/4-1/2" of the stuff lining the pipe, maybe less... but it's hard to gauge the thickness exactly. I gather from research that this is Stage 1 creosote.
I found a picture of what the creosote itself looks like on the Internet (this is NOT our chimney):
Ours isn't anywhere near that thick from what we could tell.
We also don't know what the upper part of the chimney looks like after the bend.
So my question is, do you think it's safe for us to burn with this kind of buildup, until we get it cleaned?
And do you think we might be able to burn this out with several small hot fires, if we let them burn out and keep checking the chimney in between?
BTW, I found this forum last Spring when we were selecting which stove to get - and you guys/ladies were enormously helpful, even if I only lurked!
Thanks so much!
Thanks so much!
