I am looking for some advice on buying a new stove.
My old CDW Sequoia is either shot, untrustworthy, or both. Time to replace it, or leave it as a decorative piece.
I would like to use wood as a primary heat source weekday afternoons, evenings and overnights, letting it burn down during the day. When I am home on the weekends, and on staycations, I would like to use the potential stove as a primary heat source 24/7.
My best estimate, based on a partial season's worth of use, is that I would use 4-5 facecord of wood per heating season.
I need to heat about 1200-1500 square feet. Two of three upstairs bedrooms are unused, and our master bedroom on the first floor seems to be too far away from the stove (other side of the house, about 30 ft from stove) to heat it sufficiently. Total square footage of house is 2,000.
Each room has electric baseboard, which works well in conjunction with a wood burner.
The Sequoia fits easily on my existing hearth. The stove is 25" W, 31" H, 21" L (front to back).
The stovepipe is 8" diameter before entering the thimble. It exhausts out of the back of the current unit (see pic). The chimney is at least double walled, outside the house, has a clean out at the bottom, and a cap at the top. It is currently clean and free of debris/creosote. The chimney exhausts above the gable of of the house.
I want to spend as little as possible, but am aware that too cheap of a unit may not last long. I guess my first question is, based on usage outlined above, can I get an inexpensive unit and get away with it?
I look forward to your advice, and thank you in advance for your consideration.
![[Hearth.com] Need advice on new stove [Hearth.com] Need advice on new stove](https://www.hearth.com/talk/data/attachments/221/221535-2d07682753b8731dc0c4919adc9753ac.jpg?hash=tQXjJ23MI1)
