need help Burning coal
kgb122055
2
Northern NY
I have a Woodchuck 2900 that burns woods great but I want to burn coal. I bought some Anthracite from a local supplier and I can't seem to get a good hot fire going. I put my furnace on the proper settings but still it seems to be too cold a fire, as soon as my blower quits running. Should it have constant air blowing in it?
Draft is very important when burning coal. Primary air should be coming through the grates under the fire. Does your unit have shaker grates?
I have the 526 Woodchuck and mix coal.
I load my furnace up to the door with wood . I then place a grocery bag with about 10-15 lbs of coal dead center on top of the wood and then top off with wood.
Works great.
Might want to check the operators manual. I don't think your supposed to use anthracite in a woodchuck. I could be wrong but it seems like I remember reading that.
I burn Bituminous.
Burning soft coal (bituminous) takes good air control & usually needs a burner designed for it, such as Hitzer etc. As was mentioned you need air under the coal bed & with shaker grates you should be able to burn anthracite, provided you do not have a V shaped grate/lower firebox. I know of one manufacturer that needed to change their furnace design because they thought they could burn anthracite in a V grate. They changed to a much larger area straight sided burn chamber with redesigned shakers. Good luck, Randy
If you don't have any luck, there is a coal forum like this one on the web. I forget the name, Google it.
You can go to http://www.nepacrossroads.com and they can help out. I tried coal in our old furnace, and like posted we had a v shaped firebox that wouldn't burn coal no matter how hard I tried. After waking up cold, and a firebox full of coal and out I gave up and stuck to wood. Forgot to add, if you don't have a barometric damper I believe you need one for coal to tame draft. Otherwise too much heat will go up the flue and not into the house. I have never seen a coal stove or furnace ran without a barometric damper.
