And what manufacturer & model do you have. We're good but not THAT good.
That doesn't help. Look for the rating plate.
It's usually attached to the bottom of the unit & to the right of the gas valve.
That's where the model number is.
When did it last work OK?
Thanks MILLBILLY, my Voltage to the MAIN registered 1.85v while switch and Pilot were ON.. However, I can't figure out how to have a peek behind the burner orifice? See my picture attached, I can't figure out how to remove that whole piece where the flame comes from (with the slits).. Any suggestions? thanks.. .Check voltage to main burner valve. If good then check behind the burner orifice for a spider nest.
Maybe will help him too..View attachment 218995 Link Removed Link Removed Link Removed View attachment 218993 View attachment 218994 BLADE: I don't think it has a blower, I've looked all around and took a pic of the exhaust port outside, appears to be just a simple opening.. Is there a way to test with my meter if the thermo couple is failing to open the gas valve?
DAKSY: Thanks, got the pan all apart and can see clearly into the GAS line, no obstructions that I can see.. After a lot of googling and reading, I'm leaning toward the Valve or Module being bad... Do you guys know of a way to verify if one or both are bad, like with the meter, or should I just order both and replace both.. I found a valve for around $100 and module for $60.. all help MUCH appreciated guys..
Follow step "E" in my post dated 17 Dec to test the module
Did you verify EVERY other step in the troubleshooting procedure?
Valves very seldom go bad.
Did you try "rapping" on the gas valve with the plastic handle of a screwdriver?
