Here is what my set up will be:
fire place size:
width: 26
height:26 (after new hearth install)
depth: 18
I am 99% sure I will be going with the jotul f100.
I finally got my damper cut out of my fireplace and I am working on figuring out What liner kit is going to work best with my stove, www.chimneylinerinc.com seems the have the best prices that I have found. Here are a few pics of my damper area:
The piece of turf I am holding up is 7 inches long. What is the actual dimensions of a 6 inch ss liner with the insulation wrap? Could I just skip wrapping the first couple feet of the liner? Its going to be tight in there either way I think. I am unsure of what bottom attachment I should get. I am afraid if I get a Standard T, removable snout and clean out cap that it may end up pointing up with the way the liner is going to come through the bottom of the chimney. I guess that really depends on how flexible these liners really are. I am going to be running out of space though. It looks like the f100 needs about 22" to run the pipe out the back. That Leaves me with about 4 inches to work with.
ng[/url]
[/img]
I plan on the back of the stove setting pretty much flush with the front of the fire place. I think this will be pretty close to me set up:
Would I be better off going with the Standard Liner to appliance vertical connector and then adding some stove pipe to it?
Any ways I am babbling and thinking out loud know. If any of you gurus has any tips that would be great.
fire place size:
width: 26
depth: 18
[/img]
![[Hearth.com] Need help planning my liner install [Hearth.com] Need help planning my liner install](/talk/proxy.php?image=http%3A%2F%2Fwww.chimneylinerinc.com%2Fimages%2Fstackac.jpg&hash=12f940fb486cd45732cc4579bc3904d2)
