I have a 5-6 year old 5660. I have to manually light for a couple of years, figure its igniter. The issue is, after turning off the stove by off button, it would shut down, fan would stop when cooled down. But, the blower fan (circulation fan) would come back on, sometime hours later, but not all the time. So I started unplugging it. Till next use. Upon plugging in for use, sometimes the fan would start up immediately (again, this is the circulation fan - the exhaust fan always seems to be doing its thing), but not always. But now, after manually lighting, and its burning for 10 or so minutes, the fan never comes on, stove feels pretty hot, then the 1 & 5 lights flash, and shuts off. The circulation fan never coming on. Same thing after several tries. Did a good cleaning on it today, it was needed. With renewed hope...same thing again. Help! We need heat. I read to jump or bypass some parts, but a bit unsure on how to do, especially would like to test the fan. Also, did noticed that the burn pot and a bit of a warp in the back side and a hairline crack. One more question, how important is the back 'brick' front, does have some significant wear. THANKS for any and all help.
you must bypass the POF Disk to run this test)![[Hearth.com] Need help with my USSC Bayfront model 5660 [Hearth.com] Need help with my USSC Bayfront model 5660](https://www.hearth.com/talk/data/attachments/252/252193-daf1de02e37c68ae4f8a13bfb7310d7d.jpg?hash=p6sksYdyvy)
Now, I found a F140-20F on Amazon, but mine is a F140-10F ...Compatible ? Thanks ---- Any suggested links?
