Brother Bart, why did you close down the thread I posted? The questions I asked are legitimate and I appreciated the answers I received. I get that the subject is controversial but that's all the more reason to have the discussion; to see if we can separate out the legitimate concerns from those that we don't need to worry about.
In answer to some of the questions, the smoke seems to be coming off the top of the stove. It had disappeared for a time. Most likely the pipe soot had blocked the leak. But the dealer recently added a collar at the base of the stove pipe and now we can smell it again. However, it might also be coming from the cat probe hole. I'm pretty sure the door is sealing tight.
Occasionally, the stove will stall and then, after I turn the t-stat all the way up, there's a sort of explosion inside the stove where all at once the flames ignite. When that happens, it blows a big puff of smoke into the room right at the seams between the collar and the chimney. However, there's a leak separate and apart from that too.
At this point, I'm quite frustrated. So much so I'm thinking of shutting the stove down until we can figure out what's going on. We have an infant and I don't want to hurt him. Can a child survive wood smoke? I'm sure. My mom smoked when I was a kid and I'm alive. But it wasn't the best thing to do.
We live in Bellingham, about 2 hours north of Seattle. Overall air quality is excellent.
I notice there's usually some smoke coming from my stove. It's a catalytic stove, a Blaze King Ashford. I wonder sometimes if it should burn more cleanly. Most of the pollution goes up and drifts away, particularly now that the stove pipe has been extended to 26 feet. However, at wet times (like this morning) the smoke will sometimes blow downward into our yard. It's a modern house so the windows should be relatively tight. I don't know how much pollution gets in but the 70% number that I read scared me.
