I ordered my Englander 30 from Home Depot about an hour ago.
I need some assistance, making sure I get right chimney piping.
I am planning on ordering everything from Mendards.com for the chimney.
I spoke with Selkirk customer service today and explained that I am running all brand new chimney, new installation.
it is going to be going straight up, no bends,
from the Englander 30 it will go straight up (ceiling height about 9FT) to a drywall ceiling with blown cellulous insulation.
at the ceiling it will change to double wall chimney, and then go through my steel roof.
the roof does not have any sub board, like plywood, ect under it. it is a plain steel roof attached to 2x4 runners.
they recommended a ceiling support kit for the inside drywall ceiling
and they recommended a Rubber Boot flashing kit, for the steel roof.
I am ordering 3 class A double wall sections of supervent, which should take me to the correct height outside, if it doesn't I will add another on.
my question is concerning the single wall black pipe inside.
1. so I need an adapter of any sort at the stove itself?
2 I am planning on using a simple snap together single wall black stove pipe. (is that ok?)
3. I am planning on ordering a 18" slip connector to put in the single wall black pipe. ( this is ok?)
the for the single wall pipe, I am running up to the ceiling mount kit. it will ahve an insulation guard.
can I run black pipe right up to the adapter on the ceiling support kit, or do I need a section of double wall that extends into the living space?
