Hi all,
Thanks to everyone here for sharing and posting pics of their installs. It has helped me tremendously. My new CW2900i is sitting in the garage awaiting install this weekend. I've read tons of install posts, watched many different liner install how to videos and read the block off plate instructions a few times over. However, I still have a couple of questions that I can't find answers to and I want to review one last time that I'm am doing everything in the right order.
The chimney has been swept, inspected and the damper has been cut out.
So here is my plan:
The only thing I can't suss out is how do I slide a 400 stove back and forth multiple times when testing connection the liner, installing block off plate and then connecting liner finally?
I think I saw a video of a Blaze King Princess install where the installer had think strips of metal to slide the Princess in and out. What other tips can y'all think of to make this easier on my back?
Lastly, my hearth is not level. What does one use to level a 400 lb. piece of steel?
Thanks,
Sean
So here is my plan:
- Clean fireplace firebox and smoke shelf one last time prior to install.
- Create template for block off plate.
- Fabricate block off plate.
- Insulate SS liner.
- Drop SS liner down flue.
- Attach liner to stove to ensure proper length.
- Slide stove out of fireplace enough to install Roxul and block off plate.
- Place Roxul above damper area around liner.
- Install block off plate. Seal as necessary.
- Slide insert back into firebox .
- Trim liner excess.
- Install liner top plate and seal.
- Install chimney cap.
- Connect stove.
- Light fire.
- Drink whiskey.
- Bask in warmth and glow of fire and whiskey.
Thanks,
Sean
