Hi All:
Quick update, and a question regarding my new Jotul 500.
Update: The old VC Resolute is out in the garage, and the new Jotul 500 is on the hearth! Tomorrow, the chimney gets cleaned, and on Monday, they officially install it, permits and all. I will post pics when the install is all done.
Question: the stove pipe will run out the back about 12 inches, and then turn up into 35' of 6" liner (chimney is in the center of the house). I've never had a draft issue, and was wondering if I should put in one of those butterfly dampers in the vertical pipe?
This will be my first stove without a traditional damper....and reading the reports of the Oslo's "going nuclear", are a bit worrysome. I"m hoping this stove is going to be easier to operate (and have longer burn times), than my old 30 yr old VC Resolute Acclaim.
The red arrow in the pic below shows the location of the new stove.
Thanks all!
Doug
Thanks all!
Doug
I suppose that All EPA stoves suffer this, so sad! Now once You get it fired up then she will climb on her own air, dont seem to be able to find where the air holes are in the fire box? But incredible to Me is with piles of hot coals and thro dry wood on , shut the door and it will not of its own air build a fire, have to open the side door place in screen and let it build
