New masonry chimney
Benstown
4
Iowa
Glad to be a new member, and I need help. I’m building a house and am planning on laying up a brick chimney through the center of the house, and plan to use a JA Roby Cook lx on the main floor kitchen. I love the aesthetics of the masonry chimney as the house will be rustic. I have found so much conflicting information and am not sure how to proceed. It seems the options are vitrified clay liner, or a stainless liner, or both? I want it to be safe, and I feel like the stainless liner is the best option. I see flexible insulated liners, double wall stainless, triple wall stainless… any advice would be appreciated . Stovepipe to roof is approximately 16’, there is a basement but no stove with be installed down there. Sorry for the basic questions, but I’m a little lost.
begreen
Mooderator
Staff member
Nov 18, 2005
102,515
South Puget Sound, WA
An insulated stainless steel liner will give a good long service life and will be easily replaceable when that life is over in 20-30 yrs. if the liner is heavy-duty flex or rigid stainless.
Benstown
4
Iowa
So if it’s inside of a brick chimney with no clay liner, will insulated double wall suffice or should I go with triple wall?
begreen
Mooderator
Staff member
Nov 18, 2005
102,515
It sounds like you are thinking of class A chimney pipe. You don't need class A inside the chimney, double or triple wall. A single-wall, flexible or rigid liner that is properly insulated is sufficient.
begreen
Mooderator
Staff member
Nov 18, 2005
102,515
Note that heavy-duty flex liners are hard to find. Usually, only professional sweeps get them. Rigid liners are easier to locate. They typically come in 4ft sections. With either system you will need a matching T snout that goes through the thimble. Also, think about adding a cleanout by extending the liner below the tee to a second capped tee on the bottom at the cleanout door.
Benstown
4
Iowa
Thanks so much for the reply. Is there any drawback to running the liner all the way down to the basement so the clean out door could be down there? I didn’t know if it would create a problem having 12 foot of unused pipe below the tee/thimble.
begreen
Mooderator
Staff member
Nov 18, 2005
102,515
As long as the bottom tee is well sealed, it's ok to have the cleanout in the basement.
bholler
Chimney sweep
Staff member
Jan 14, 2014
32,880
central pa
That much extra pipe isn't ideal but as long as everything is sealed and insulated it will work fine. And put the clean out waist to shoulder high to make it easier to clean from the bottom.
Reactions: begreen
Benstown
4
Iowa
Good advice! I guess I would’ve imagined putting it close to the floor but it makes sense to put it up higher
