They got the green light from BK to use mill-pac (actually got permission right after initially coating everything with furnace cement), so I'm guessing that will be the approach in the future.Block off plates are not common with stove installers at all. It is not required by code at all so they don't do it. But it really does make a big difference. The furnace cement it far from permanent it will crack and crumble away shortly
I'd honestly like to see a 15 used in there so it seats a bit better, but they were limited at the time to what was supplied, the 30. That is a bit unfortunate.
I snapped a few pictures of what I have going on above the unit now. They wanted to make sure it was not going to leak, but I'm not sure if less is more in these cases. haha.
You can see the original damper which was removed however many years ago and served as the hanging point for the old barely insulated block off plate from the country comfort. It was actually only held up by two metal pipes behind the stove and optimistic gravity. With how leaky and poorly installed it was, it served very little purpose now so it was discarded.
Before anyone asks why I didn't install myself and do things like the 15 angle and block off plate, to get the tax credits and insurance blessing it needed to be installed by a certified professional team.
![[Hearth.com] New Princess 29 Insert - Questions - Running Very Hot & Installation [Hearth.com] New Princess 29 Insert - Questions - Running Very Hot & Installation](https://www.hearth.com/talk/data/attachments/294/294103-343fc5d5e36d7035211961755a8ffb5f.jpg?hash=-LxHgRDwZD)
