New question - need help with setting for castle serenity
Yvone
9
Central Oregon
Hello
I'm at 4400 ft and have new control panel. Need beat setting possible so that it wont keep heating house above designated temp. I prefer set at 68, knowing i'll mediate space will heat ro 75.
Issues in past, heat set at 62 and it keeps going and we have manually shut off at 80 or higher if we miss the 80 spot.
I'm in pre 70 metal mobile at 4400 ft in base of mountains.
Thank you for helping me.
Yvone
Unfortunately the Serenity does not cycle off and on when set temp is reached it just drops to low burn so other then opening a window or shutting the stove down there isn't much you can do if it's over heating the home.
I know this.
My issue is that the darn thing keeps heating beyond the designated 62. I'm not trying to be nekkid all the time and heating outdoors too.
Maybe I'm not understanding what your asking. But if the stove is on it's going to keep heating no matter what the temp is set at because all it can do is drop to the lowest heat level.
Maybe drop the temp setting to 52 and se if it balences out better
Ok thank you
But go figure, now the augers wont feed after initial feed. I've emptied and gonna vacuum dust out.
This is new control panel. Last two control panels were way off. First one would heat to 97 before shutting off
Second one I had to turn off at 80.
But we (company rep and self) changed blower and other settings.
That was what I was looking for here m. Help doing rhat.
Hello
Yvone
Here is what I used on mine.
(broken link removed to https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F163374074447)
Looks like a good idea ,,,but a little pricey
That's pretty cool. I dont have issues with mine yet, but I will keep this auger control in mind. Thanks.
