New stove install help
MikeyP
1
MA
I could use some help figuring out how to install vent piping for my new pellet stove. I purchased a Castle pellet stove and have a hearth with pipe through the wall already (See pictures below). This chimney has not been used before (house built in the late 80's). I had a chimney cleaning company come and clean/ inspect and they gave the OK, said all looks good.
Please correct me if I'm wrong and point me in the right direction but I think I need this adapter: (broken link removed)
Along with this other adapter: https://www.lowes.com/pd/Simpson-Dura-Vent-Black-Chimney-Adapter/3134693
Then just normal 3in pellet stove piping down to a T adapter and then stove.
Any help here is greatly appreciated!
[Hearth.com] New stove install help [Hearth.com] New stove install help
I did 2 stoves into an existing flue through a crock like yours. One I had the dealer install, the other I did myself. In both cases I simply ran the pipe through the crock into the flue. I then packed rock wool around the pipe in the crock. I then used a stove pipe trim collar on the inside to dress it up.
Something like this (course you need the 3" version):
https://www.amazon.com/dp/B001AT2CGU/?tag=hearthamazon-20
The dealer I believe just packed fiberglass insulation batting in around the pipe. Following the manufacturers guide on the pellet pipe I bought for the other stove I used rock wool to pack in there. Rock wool is more fire resistant.
