I should have fired her up last night, but really don't need heat for another month maybe.
First thoughts & impressions:
New design, there is s slight whistle and flapper clanging at one of the air intakes, either primary or secondary at the EBT.
Sounds more like the right front(looking at the stove face), leading me to think there is a new design on not only the EBT, but also the primary air intake. My guess is there is indeed a draft controlled flapper at the primary air intake. The intake does have the slight whistle as I noted and the flapper at first made me think there was a bat or mouse in there LOL. But I noted as I opened and closed the door, the sound is distinctively a draft operated flapper, as it clanked more along with the opening and closing of the door.
Never heard or experienced this with the old A model Summit.
Slightly annoying, but will get used to it I am sure, and the fans drown that out.
Just a break in fire, so some secondaries, but no major stuff.
Not getting cold enough to go for any serious heat.
Fans came on when I just went out at about 350
2 fans(one each side) as opposed to one large one on the right side with the A model.
Fans sound and feel just as powerful, but this new design sends maybe 75% of the heated air over the top plate cover, and 25% underneath the plate to over the door. No opinion on this yet.
About just as loud as the old fan. I don't have a problem with that, the tv always goes louder.
And I actually like the sound of the blower(s) as it is white noise for me, and soothing, knowing it also indicates heat is in operation.
Door so far, does not appear to feel looser as when the insert gets up in temps.
Old insert did this.
The door already feels snugger than the old one ever was. Old door btw.
I am waiting for the new one to come.
I laid the bricks put to dry a couple days and no real moisture came from them. The steel inside did let off a lot or moisture and that fairly quickly burnt off.
The baffle at 100
did obtain a very slight sag in the front middle.
The baffle has 2 more rows of port holes on each side of the center one all running front to back about 1/3 to 1/2 the way back from the front.
I seem to remember the baffle appearing to have weld spots towards the mid back. Maybe they added stiffeners inside to help with sagging & warpage. I am not really worried about that as the old baffle was warped pretty good and did it's job without a problem.
The boost manifold bowed slightly also. I do know it is slightly shorter side to side than the old one, note sure if they changed the material composition or used a different thickness. Didn't notice.
Not concerned about this either.
The paint curing smell is no worse than the previous model, slightly mild stink, no headache, no nausea, just smells like something baking. Now I have fresh baked bread on my mind.
Won't get to check the secondary flamage or EBT differences for quite some time, but that day will come soon enough.
Appears to heat up and put out heat in similar way as the old model.
So far, very happy. But has not been put to the test yet.
I'll post a vid if/when able
The baffle at 100
