Hello everyone, my name is Ben, I live in King's Lynn Norfolk UK.
I have recently had a log burner installed in my home, I had a professional company install the burner costing me over £2000. I had a Charnwood Country 4MKII 4KW installed. It's a beautiful burner.
I have had the burner in for a week now and I'm terrified of everything, every noise, is it too hot? Too cold? Too smokey?
After looking through numerous forums this seems the most friendly and helpful.
I'm looking for some advice;
1; How should I have the air controls on my burner? I have had the primary control (bottom) fully closed and the secondary control full open up the log catches fire when I reload. Is this correct?
2; Sometimes I really struggle lighting my fire, does anyone has any tips? I've heard not to use newspaper as this can cause fires up the flue? I have been using small firelighters.
3; The glass on my burner seems to get very dirty in no time, I'm using wood that has been sat undercover for 2 years but I've only just got the wood splitter out and split it.
4; What are people's views on leaving the burner alight when I'm not home for a couple of hours? How should I leave the air controls? Should I load it with wood before I leave?
5; I am thinking of buying a flue thermometer and a DIY Chimney sweep, are any of these any use? Or am I wasting my time?
Thanks for you time, I would really appreciate any help! I look forward to hearing a few replies and enjoying my burner safely and efficiently!
). If you are getting black glass - you are more than likely get black inside your pipe. This requires inspection and maintenance. Cleaning the pipe is referred to as "sweeping". The whole idea is to remove anything that has accumulated in the pipe reducing/removing potential fuel for a fire. It will also remove the normal accumulation of ash if there is any.
