I recently had a VC Encore installed new and am having some issues with it backpuffing, it's preventing us from using the stove now that temps are dropping and I wanted to reach out to get some help since we're new to this.
When I close the damper and reduce the air, it's the most noticeable and occurs with greater consistency. It did it bad enough last night to lift the griddle and you could hear it, but normally it's just visible. It's much more noticeable when the thermostat is closed down even a tiny bit, but I've had it do it full "open" (hottest) also but not as much. It doesn't happen when the damper is opened up, only closed with the cat engaged. I've tried reducing the temp very slowly several times, but it still happens. I've read other posts that suggest leaving the damper partly open, but the manual indicates the damper is an either all open or all closed affair, attempting to crack it a bit just results in it falling open, so that doesn't seem to work even when I tried, it will either only stay closed or open.
The manual states when this happens to open the damper to cool it down, which makes 0 sense because it actually heats the whole thing up, so that isn't much help either. It gets too hot for our use case and burns the wood faster, obviously.
Our install uses 6in straight pipe and a fresh air draw from outside. There is no blockage in the catalyst or chimney, it's all new and I looked to verify. Our wood is well dried, around 12-15% when I measure moisture down the center after splitting a piece. It seems to occur mostly after the wood has burned a bit and doesn't seem to matter if it's to the front or rear of the stove. I also verified the holes in the rear aren't blocked.
I noticed last night that it appears to only happen when there is no visible flame on the wood, it seems like the flame is being pulled into the rear chamber and reduced on the logs when the damper is closed, the logs just have glowing embers on them visually. When I open the damper, the flame pops back up. When there is an active flame off the logs then it doesn't occur, the problem is how do I keep that going overnight to prevent this from happening? With the damper closed, the size of the flame cuts down almost entirely and becomes inconsistent, I've yet to see the logs remain visually lit with the damper closed for any period of time and when it is there, it's usually small and to one side of the stove but dies after 30min or so.
I understand this is due to off gasses developing but not being burned or drafted out at a fast enough rate, but I'm not sure what to do about it.
Thanks for the help.
