Howdy...
I just moved into a home in central CO at about 6,000 feet elevation. Winters here aren't horrible, but it gets its fair share of cold nights and windy cold days. I have a 2,200 SF home with about 1,000 on each level, both with equal amounts of living quarters and bedrooms. Presently I have a gas boiler and solar thermal tank (with collector tubes on the roof) that heat the in-floor radiant heat. However, the bottom story does not work and I believe it is due to some of the valves and pumps being inoperable. I am trying to find a plumber or solar tech who can help analyze and fix that.
I also have a wood stove on each level. These make up my heat sources. The bottom floor wood stove is a Scan 61 which we don't like. It's too contemporary looking. The upstairs has a Vermont Castings stove that is about 22 years old and needs some work. It has a CAT element that most people seem to like, but I'd rather have a modern design that doesn't need the CAT. Trying to sell both here:
(broken link removed to http://westslope.craigslist.org/hsh/4092950715.html) I attached pics of them also...sorry they are dirty.
I like the idea of an exterior wood burning furnace because from what I gather they can be configured to heat my domestic water, in-floor heat, as well as blow forced air into the home. Is this right?
I have other questions and info that I have drafted below. Long post...sorry.
We are considering upgrading our heating sources. Each level has about 1,000 SF. The downstairs stove is in the center of the floorplan. The upstairs stove is on one corner of the floorplan. Not sure what I should replace the current poor condition stoves with. We want to upgrade them with something.
Fallen and standing wood (mostly Juniper) is plentiful on our land, and purchased wood is about $160 a cord for dried/split evergreen types, delivered. Hard wood is harder to find and is more expensive, like $235+ for a 4x4x8 cord. Pellets are available for about $205 a pallet. I think those are 50, 40-lb bags on each pallet.
I have never used burning stoves before so I'm getting smart on them presently. Was wondering if anyone could recommend what would be the most user-friendly and versatile due to our home design and needs.
I sort am leaning towards putting a pellet stove in the downstairs playroom where the kids sleep and a wood stove or alternative burning stove (like a Rocket Mass Stove) upstairs in our living room. I thought this configuration would give the most safety and be versatile. That way if we are ever powerless we can still use the upstairs wood stove for emergency heating/cooking. And the downstairs pellet stove could be used as-needed and not require so much tending to. I understand pellet stoves don't require as frequently cleaning because they burn more controlled and higher temps.
Questions:
1. I kinda like the longer stoves with the door in the front and the vent in the back. Are these good designs? I figure they would be best for loading and leaving the door open (because the wood is in the rear). A drawback may be harder to clean from the bottom-up due to the vent location being in the rear and the stove being longer. There is one here fore just $280 from Sportsman's Guide. It seems a tad small though:
http://shop.sportsmansguide.com/net/....aspx?a=609100
2. A local wood stove place disuaded me from buying a CAT element stove because of the routine maintenance and he said the newer wood stoves with their reburning designs are almost as good as the CAT stoves. It also disuaded me from buying a pellet stove because of the cost of pellets and need for electric power (but we don't have that many outages).
3. Is glass on the front of a wood stove problematic or negatively effect heat output? I think solid metal would radiate more heat and hold it better/longer. Is there any functional benefit to having glass?
4. I have these concerns to cover with whatever I buy: The upstairs hearth area is all protected, but the downstairs is not (see pics). I am concerned my wife needs a simple design that is difficult to mess up, as she is busy with kids and isn't as observant as I am...so I am concerned about fire hazards basically.
5. Is there an interior wood stove that heats water/glycol and use radiators in the home to disperse the heat? Or some other form of dispersion like forced air from the exterior to the interior (if this exists)? Something like a Hardy Heater? Or must I have an exterior furnace to heat my radiant heat and domestic hot water?
6. If I have the space should I consider a cooking wood stove so it is more versatile and holds more thermal energy to let off? The couple I have seen online seem to have a very small opening for wood. We would not cook on it much, only for fun or in outages or if were out of propane.
7. Is a Rocket Mass Stove an option? Are there professional contractors that will build one while I observe? They look really sweet, but unsure how safe they are and if they have been proven to be reliable. Can the Rocket Mass Stove be modified to heat domestic hot water too? I have in-floor radiant heat that is hooked to a gas furnace and thermal collector tubes (solar tubes on the roof). If the Rocket Mass Stove could be used to burn wood and supplement the in-floor heat and domestic hot water, that would be ideal. Right?
Your thoughts and guidance are very much appreciated! Chris
![[Hearth.com] Newbie in cold climate looking for advice on what to install/upgrade [Hearth.com] Newbie in cold climate looking for advice on what to install/upgrade](https://www.hearth.com/talk/data/attachments/112/112916-c790d66020e8b4d6250062f84cc02b6a.jpg?hash=FT7Gnhh7xD)
Questions:
