In the process of building a new home and a wood burning stove is in the mix. Purchasing the Shelburne due to size limitations. I have read a ton of threads, and read through countless manuals about installs. I will be doing a wall pass through, into a chase.
What is the ideal set up for this stove. I'm thinking of going up 3.5-4.5ft and installing a 90, and then exiting the room. ( 1.5ft or so horizontal run). I plan on double wall, vertis stove pipe and chimney. Double wall is strictly for closer clearances to unprotected surfaces. I've read the max chimney height for this stove is 30ft. I'm going to be very close to 30ft with the chimney. Does the stovepipe need to be included in that measurement? ( Some stove manuals I've seen have drawings with ideal lengths/max lengths of stovepipe listed as well, however the Shelburne does not. I'm in South Carolina, stove dealers in the area just seem to be salesman, haven't seemed very knowledgeable about anything. Any insight would be greatly appreciated.
