The last few weeks have been interesting. We finally had some real drying conditions(for NW Oregon) and all but the smallest split outside have now lost more moisture than my control in the garage. They should have, as all but 1 were heavier to start with.
It is clear from my data that the drying rate is driven by how wet the wood is and the Equilibrium Moisture Conditions (EMC) outside. The farther apart these two are, that is, the steeper the gradient, the more grams of water my splits lose. Period. If nothing else, understand this and you will know how your wood dries. Clear from the graphs are that in the first half (~45 days) about 3x the water is lost than in the last half even though the drying conditions have been much better in the latter half. I like to use the EMC calculator here: http://www.dpcalc.org/ to see how a few degrees changes the RH and EMC. It helps explain why so little moisture is lost at night and while the control split in the garage can lose more than splits outside especially at night.
Two weeks ago we had a nice 83 degree day between a 70 and 71 degree day. Even though the average temp was only 3-4 degrees warmer, the splits lost between 3 & 4 times as much moisture as the day before and after. See data table. Meanwhile, I started drying 4 fresh c/s maple that same day. While the 2 month seasoned fir lost an average 46 grams that 80 degree day, my wet maple lost an average of 246 grams. It's moisture content was higher = steeper gradient, so they lost more moisture.
With 2 rain events this last week, my Doug Fir splits have lost almost nothing, even the 4 splits under cover gained moisture during the week! But the 4 fresh maple splits I started just a few weeks ago still managed to lose an average of 133 grams. Almost 3 months down and my fir splits have lost between 31.5 - 45.4% of their starting weight. That means that if they all started at 95% MC the driest would be at 7% and the heaviest would be at 34%. They clearly didn't start at the same MC, but it points out that after equal drying time, the size and shape of my splits has a huge effect on their current MC.
It's clear that if you have the room and time, stacking splits in a single row for a couple of years will usually get the job done. But drying inside can be equally effective and considerably faster during some parts of the year especially when temperatures inside are slightly above outside temps. (Nov-May in NW Oregon) Some have said that wood doesn't soak up the rain like a sponge and that is "kind of true". It will get heavier after rainy or wet periods, even if under cover, but that moisture is more quickly lost than the first time it was lost so in the long haul it is not a big deal when we are just trying to get MC's under 20%. But if you're trying to dry quickly, it slows the process. And of course the dryer the wood the more likely it will gain weight in wet conditions.
For the curious, my control split now measures 15% on the moisture meter after 87 days of drying and since it is loosing just a few grams per day, I think it is pretty close to equilibrium. If the meter is accurate, it means it started at 87% MC which I think is about right. Also, being in the garage, it has never gained wt throughout this drying process.
To see how bad our "seasoning weather" has been, check out the monthly weather summaries here: http://www.wunderground.com/history/airport/KPDX/2011/6/23/MonthlyHistory.html#calendar
If you really want to know how your wood is drying, get a scale and see when your wood is really drying and when it's not! What I found is that there is a lot of wasted time in the typical seasoning process.
To recap: I started seasoning some splits from a 120' fir felled, c/s/s the same day and started weighing back on April 18th.
Previous post:
https://www.hearth.com/talk/threads/75789/
Previous post:
