I believe that the ethanol is not a problem if your storage is correct to prevent moisture from getting into the fuel. Temperature and humidity controlled storage or even sealed metal cans the dang stuff can last a very long time.
All of my saw, mower, generator, weedeater, tiller, etc. gas is regular ethanol laced pump gas. Never had a carb issue and these engines often sit for a long time between uses. The chainsaws can sit 11 months unused on the shelf and then fire right up to process a load of logs which I'm hoping starts here next week!
Saws that have been treated like this MS290, Dolmar 6421, husky 372xp clone.
Western WA is a pretty wet place too. I should add that I religiously use the regular red sta-bil with all gas and I keep and rotate four 5 gallon plastic jugs so the fuel starts out about a year old before even mixing in the echo red armor for the mix gas can.
