Noticing build up around chimney cap
KG19
89
SW Wisconsin
This morning I went out and took a peek at my chimney and noticed what looks like a lump of creosote up by the chimney cap. It looks a bit worrying to me. But it’s also confusing because I’ve been burning quite hot, in fact almost too hot on occasions. I posted about a month back about overdraft on my Alderlea T6, then had a damper installed and also covered the boost air hole. These steps helped a lot to where I have a more controlled burn. I don’t use the damper often anymore since covering the boost air, and typically run with flue temps (on probe thermometer) in the 600-650 F range and STT usually around 600-700. I get good secondary combustion and am using 3 year seasoned wood, mostly ash.
I hadn’t noticed this until today, and I do typically take a peek at my chimney when burning every once in a while to monitor smoke. I usually have very little to no noticeable smoke except for a few minutes on reloads. And like I said I hadn’t noticed any of this creosote looking substance until today.
Something else to note is that we’ve had a cold snap here the past few days. The highs have been in the single digits with overnight lows below zero. Wind chills down to -25 F. Could that be maybe causing this condensation just around the cap? Or do I assume that my flue is getting build up and I should inspect/sweep? I’ve only been burning for about 1.5 months consistently with a brand new insulated liner and brand new Alderlea T6.
I’ve attached pics but it’s hard to get a good view with my camera due to the height of the chimney. In person it looks more noticeable. The screen itself seems pretty clear but it seems to have “build up” around the bottom edge/crown of the chimney itself. Almost like ice build up but it’s black. It seems to be really only on one side of the chimney.
  • [Hearth.com] Noticing build up around chimney cap
It's not uncommon for creosote to condense on the underside of the slab of a big cold lid. The tall brick chimney can also be cooling down the flue gases below 250º. If so, they will start to condense. It wouldn't hurt to sweep as a check to see how things are looking.
I'd go up when it can be safely done, do an inspection and clean as necessary. When my screen starts to get a little buildup I pull it, clean it and the top 2 feet of my liner that sticks out of the masonry. Everything else is always fine for me.
KG19, is there an insulated 6" stainless liner in the chimney?
Yes:
That will help keep the flue gases hotter. Hopefully what you are seeing is just creosote building up on the underside of the cold lid.
It’s gonna get warmer here this weekend so I’m gonna take a look up the flue and sweep if needed. Any insight on this cleanout setup they installed? The end of the liner seems pretty well secured in place and no way to remove it. Is the cap above it the cleanout port?
This system is new to the new install… we used to sweep right from the main floor by detaching the stovepipe. When they installed the new liner they ran it to the basement and put in a cleanout down there, but I’m not sure what the cleanout spot is
Not sure, it's going to take some exploring or call the installer. Whichever it is, label it when you find out.
