cant figure out if this is on the high end and in line with last year. Doesn't seem like we should have used that much since end of September.
Ya, I was hoping to have not started burning so soon myself but when you burn it adds up ! A bag here, two bags there over two months time can equal a half ton or 25 bags depending how you want to read that. But in my case I have not started on my stash for the season yet. While we started early, I burned off some remaining pellets from last year and have bought some individual bags weekly since those are gone now. Trying to make Thanksgiving before I tap my stash. But my stove is not a pellet pig, I like a warm house and the house is a pellet pig !!cant figure out if this is on the high end and in line with last year. Doesn't seem like we should have used that much since end of September.
Cape Cod has been up and down, we have had frost some mornings and 60 deg days other times. This is our second bit of snow, first that collected a little bit on the grass. The last time was just flurries. I think we are setting up for another tough winter.That's a lot of pellets so far. It has been way too warm to run the stove on a regular basis. I've used maybe 2 bags. I think that's going to change today.
!That's a lot of pellets so far. It has been way too warm to run the stove on a regular basis. I've used maybe 2 bags. I think that's going to change today.
About 13 bags of Lignetics hardwood since mid-October here in NE PA at an altitude of 1360 feet. Normal. Stove is a Harman Accentra insert set at 69 - 70 degrees operating in room temp mode.cant figure out if this is on the high end and in line with last year. Doesn't seem like we should have used that much since end of September.
Is that the blue or green label ligs?About 13 bags of Lignetics hardwood since mid-October here in NE PA at an altitude of 1360 feet. Normal. Stove is a Harman Accentra insert set at 69 - 70 degrees operating in room temp mode.
Hey by spring time you will get over that !!Burned 1/2 ton also. Part my fault because I'm a new pellet stove owner and just burning when I probably shouldn't have. New toy, had to play.
Only 50 so far and your in Fairbanks?Bag # 50 got dropped this am. I'm hoping my stash of 7 more tons will last till may
Nah, he just isn't telling us that his house is just 700 sq ft and he is burning two P68's !Only 50 so far and your in Fairbanks?
You must be well insulated.
