I am in the process of buying a maxim 250 outdoor pellet boiler and they are equiped with two seperate output/input line. so one will go via thermopex 75' underground to my house while the other was going to be used to heat my garage which houses the boiler. the problem is I have an overhead rad/fan heater in the garage that i currently heat with my pressurized wood boiler (eko40). the rad is located higher than the boiler, Will the water just pour out the fill cap? I know they are not technically pressure vessles but there will only be the weight of watever water is in that rad (maybe 5-10 gallons at the most) essentially I'm trying to eliminate the hassle of another water-water exchanger and a second pump.
My house is pretty well insulated and is about 2800 sq feet with lots of south facing windows but my garage is poorly insulated and 24x38 so I would really like to be able to use the garage to "dump" some of the excess heat that the 250k btu boiler can put out therefore reduceing cycle times. aka heat garage warmer when house is warm and cooler when outside temp is cold and house is in need.
please pitch in if you own a maxim pellet boiler as well, any info or advice, thanks
