Oxygen barrier Pex or regular pex?
NCFord
203
central NC
I went to the plumbing shop yesterday to pick up some 1 inch pex for my boiler install and they did not have any oxygen barrier pex. I have gotten some there is the past but now it is special order and $1.80 per foot vs.
.85 cents per foot. This is for the 20' straight sticks. I only need about 120 feet so I don't care too much about the cost. What I need to know is if I should use the O2 barrier pex or is the regular stuff ok. This will be used from my pressurized primary loop. The guy at the plumbing shop said that you don't need o2 barrier pex anymore....I don't believe him otherwise they would not make o2 barrier.
that's what I thought.
Around me o2 barrier is code. Plus, for steel boilers (nearly all of them) you'll want it. You don't want o2 barrier for domestic water, that's all.
I'm not using any for domestic water, but why would you not want it? I get it for boilers but regular water lines?
I'm not entirely sure, to be honest. I wonder if it had something to do with the wide range and speed if pressure changes. I was just told I'm not supposed to use it.
Your DHW is not a closed system like your heating loop. Oxygen in your DHW system is purging every time you open the taps - plus I don't think there is much in your dhw system that will rust - your taps etc. are probably stainless. With your heating loop you are going to want to manually purge as much of the air out of your system after fill up, and then have the proper scavengers in place to remove any o2 that happens to get into the system over time.
EDIT - Probably the short answer is "just to save money." Non barrier being cheaper and all.
Definitely use barrier tube, even for an open system. It will reduce the O2 infiltration and help keep chemical additive from deteriorating.
I just ordered 2 100' rolls from pex universe for $89.00 each including shipping. I hate using the rolled stuff but oh well.
I worked with 3/4" rolled pex water line this weekend. Total PITA. Always thought that sticks were stupid but that was before I had used anything bigger than 1/2".
FWIW, if you use PEX-a it's much easier to work with. Some of the common trade name or brands are Wirsbo/Uponor Mr.PEX. My supplier sells Uponor, I find the 3/4" to be easier to work with than 1/2" or the Lowes/HD stuff (usually PEX-C). The rolls have much less memory than the PEX-c.
The O2 barrio stuff is the same material, but with the oxygen barrio applied to the outside of the pipe. It is not certified for potable water because it is not cleaned the same as it is for potable water use. But it is the same physical tubing.
TS
Is that the case for all o2 barrier tube? My mrpex o2 barrier has the nsf label and I planned to use the leftovers for potable.
What's the NSF rating? I also used Mr.Pex brand tubing for my slab. It is only label rfh for radiant floor heating. I did use it for a bathroom that was added this year. All of my actual drinking water is in copper.
TS
TS
I looked and yes you are correct, NSF-RFH on the mr. pex 02 barrier which is not the same as NSF-61 that appears on regular drinking water pex. Rats, I planned to use those scraps for plumbing projects.
Hey guys im new here and I found some of this information interesting. I have found certain information that claims you may indeed used oxygen barrier pex for potable water applications... Meaning if there is some left over you don't need to go buy more. I also read that it should be cleaned a little before use if its the silane method type. What are some thoughts on this?
This is an old thread, and without the proper NSF-61 cert. it will not be legal. "clean it a little?" not for my kids to drink from.........
TS
Well I found these post on heating help.com if anyone has heard of it. Im trying to install PEX into my home, i need a re-piping job done, so I am just checking out all of the parameters. I understand what your both saying now. Thank you.
If it's not labeled as safe for drinking water then you wouldn't pass your plumbing inspection and you could end up pulling it out down the road when somebody wants to buy your house and find that illegal pipe.
Most O2 barrier PEX seems to be NSF 14/61 rated, which means it is SAFE and certified for drinking water usage-- see the Home Depot stuff here: http://www.homedepot.com/catalog/pdfImages/ae/aec7431a-c3d5-4771-be52-603008f70c2f.pdf
So use the oxygen barrier anywhere you'd like if your brand of pipe carries the rating. I'm thinking of retrofitting some radiant floor heating by just using a continuous loop on my tankless gas water heater, mostly as supplemental heating so I have cozy floors but also so that I am a couple backup batteries away from maintaining some decent heating when my heat pump doesn't have electricity after an ice storm or so that I can substitute the gas floor heating for those extra cold times my electric strip heat would have kicked in. I have a small house (<900 sqft). Found this thread when I had the same questions and was encouraged to google it further since there was not a consensus or definitive answer. I believe that Sharkbite spec sheet offers some clarity at least for that brand.
