P61a shutting down
greywolf46
31
Eastern PA - Lower Bucks
Stove is unexpectedly shutting down. Running in stove mode auto, setting #3 for 10 hours overnight, it shut down early morning as if it ran out of pellets. I usually run it on room temp manual, but had trouble starting it recently on room temp auto. Feed motor would go on and off every couple seconds. So, I switched to stove temp auto and the feed motor stayed on to fill burn pot and ignite pellets. Ran fine overnight then shutdown toward morning. Cold outside 14 degrees.
In auto mode the stove will shut down when the temperature reaches the set point. If you want it to keep running set it to manual.
Well,my best thoughts, clean the control board potentiometers with contact cleaner. Have you had stove apart recently,to clean? If so,check the fines cover is on properly,and check other gaskets.
If you doubt any of this are issues,you could bypass the vacuum switch with a jumper and see what happens.
Just replaced the esp today and cleaned fines box. Cover on correctly. Will check gaskets.
Make sure it’s the same ESP as the original or there will be dip switches involved
It's probably something already mentioned, but could it be the pellets? Someone else had a problem recently burning pellets that were too long and that bridged in the bottom of the hopper. I had a ton of pellets that caused that to happen with my P61a several years ago.
