Hope everyone has a wonderful and warm Thanksgiving!
Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
How does the PE T5 do with low heat? Say 7000-12000 BTU. I know cat stoves are better for this but I'm looking at the T5 right now. For example, could I fire this insert at 7000-12000BTU for 4 hours at a time?
I can't comment on the T5, but with any stove, the best way to control heat output is by adjusting the amount of fuel being added to the stove. I would estimate that 3 small/medium splitz would give you the heat output that you are looking for, with just enough coals left after 4 hours to reload the same. Hope this helps
Well I can't really comment on actual BTU numbers for low burns but as said, a small fire is the key and yes the T5 is easy to control for such. It's still easy to over heat a room though, but usually that's my fault for using too much wood during shoulder season.
Yes, it will run at a lower rate of heat output with a partial starting load of 4-5 splits and then adding a few more splits every 4 or so hours. I know a few people that run the stove this way locally until it gets cold outside.
