Did the math on the cord caculator up top and it came to 1.05 cords .......that is if you were square up on both sides of the width and square on the length etc. and no air space in between rows.
I don't think that is a true cord on two pallets.
I have 48" square pallets, 3 sets of 6 pallets, and with stacking two rows, ~ 5 - 6 feet high, on the 6 pallets estimate ~ 3 cords/6 pallets... for a 9 cord inventory when all 3 sets are filled. You could squeeze more on with three rows, but would overhang on the edges and not any room for the wood to breath.
Laying a firm level gravel base is worth the effort. the pallets last longer, remain level, and allow stacking higher (than I should).
There is one problem with "true cord".
It is a stack of wood that's 128 cubic feet in size. The amount of air to wood ratio varies.
A loose stack 4X4X8' is a cord just as much as a tight stack 4X4X8'.
80 to 90 cubic feet of wood is a rough estimate of how much "wood" is in a cord.
That why many of the BTU/cord calculations & weight/cord charts use 85 cubic feet of wood.
I stack mine loose to season & tight when moved to the wood shed.
My cord of green wood shrinks as it dries, & shrinks again when I stack it tight.
I can see a 1/2 cord on a standard pallet easy enough with some overhang, but I'd wrap is with some kind of netting or chicken fence for stability.
I generally put down three pallets end to end and get a nice, full cord of wood (I round it up a bit with my punks, chunks and uglies on top) with the wood stacked in a double row . . . I have yet to have a wood pile topple on me . . . although I have had some leaners over the years.
