Ashful
It will be fine. I tore out a bunch of 30 yr old copper with leaky shutoffs and lots of internal corrosion.
... and you’re DRINKING the water that did that to your plumbing?!?
Yes and I had it tested it is a little hard and it is high in iron and manganese. Both of which are removed mostly with the treatment system. The copper in our last house was in similar condition. It was fine as long as you didn't have to use a shutoff or do anything to it as soon as you did you spent a week chasing leaks in the old stuff.... and you’re DRINKING the water that did that to your plumbing?!?
Remember those days well. In my last place, the minute I touched on of those old spin valves, I knew it would drip or worse. Had to replace a few, and was not much fun. PVC in this place, until I swap to Pex.Yes and I had it tested it is a little hard and it is high in iron and manganese. Both of which are removed mostly with the treatment system. The copper in our last house was in similar condition. It was fine as long as you didn't have to use a shutoff or do anything to it as soon as you did you spent a week chasing leaks in the old stuff.
Several posts above, the last was Hogz.Where is the brass valve criticism?
You can repack valves. IME it works half the times I've tried it.
Yes of course if the valves were maintained properly they will work. But most are not and on most old systems i have worked on simply changing out a bad valve leads to multiple leaks in that line elswhereAll this criticism of brass valves, and every PEX system pictured so far has had brass body valves. [emoji3]
