Hay guys I thought burning pine created way too much creosote. Can you burn it regularly? and if you can, do you have to clean your chimney more often?
Stove Nut
Stove Nut
Gooserider said:It doesn't have the same BTUs / pound as hardwoods like oak, and it tends to want to burn faster and hotter so you won't get as much burning time out of it as hardwoods, but it's good fuel.
Gooserider
BrotherBart said:All wood has the same BTU content per pound Goose.
I tried it a couple of times again this AM with my Mac (ibook)- doesen't work there either- (was using the house PC last night when I posted)Mike Wilson said:Go to Advanced Search and enter “Burn Pine” in the query box, then change the search parameters to only search thread titles. There are about 5 threads that have a lot of information on burning pine in them.
-- Mike
What type of pine do you have in Yukon Canada?north of 60 said:Thats pretty much all I can burn here other than poplar & (birch trucked from 200 miles away.) Run the stove 24/7 on it along with 30,000 other people in the north. If that helps ya. With the new Cat I clean it once a year weather it needs it or not. Minimum 8 monthes burning.
BrotherBart said:Gooserider said:It doesn't have the same BTUs / pound as hardwoods like oak, and it tends to want to burn faster and hotter so you won't get as much burning time out of it as hardwoods, but it's good fuel.
Gooserider
!jpl1nh said:What type of pine do you have in Yukon Canada?north of 60 said:Thats pretty much all I can burn here other than poplar & (birch trucked from 200 miles away.) Run the stove 24/7 on it along with 30,000 other people in the north. If that helps ya. With the new Cat I clean it once a year weather it needs it or not. Minimum 8 monthes burning.
WarmGuy said:I've been told never to burn eucalyptus for the same reason (creosote) -- any truth to that??
EddyKilowatt said:WarmGuy said:I've been told never to burn eucalyptus for the same reason (creosote) -- any truth to that??
Eucalyptus bark, maybe. I'm burning the wood this year, for the first time (having burned pine and cypress the previous ten years), and I gotta tell ya... this stuff burns with a blue flame. I won't know for awhile whether I'm seeing more flue build-up (fluffy dark grey kind), but if I do, you can knock me over with a feather... this seems to burn like a very clean hardwood. They originally imported the tree to make charcoal with, didn't they? (Or was that railroad ties, I forget.)
Eddy
Stove Nut said:You guys are great! I will try the search the next good chance I get. Thanks for all the info!
Pine-not so bad after all.
stove nut
