Came home and the wife says "there's either a bird or a bat in the stovepipe", so we all know how fun that game is. Took the elbow out and unscrewed the pipe so I could take the bottom 4 feet or so outside, the wife put plastic bags over both ends as soon as I got it off the rest of the pipe, and as soon as we got out the door the top bag started fluttering and this little bird worked it's way out and flew off, hopefully smart enough to not try that again! It actually was sitting in the part of the pipe that used to be a barometric damper that I had capped years ago. But it showed me a few things; I found some gaps in the pipe that I need to stuff some rope gasket in as soot was coming out, most likely from the bird flapping around, and I got to see that despite some very fine, black soot the pipe was still clean despite burning a lot of wood last Winter, but it was dry wood and I burn a little bit hot so that is why.
The main thing is I got the little thing free, and our 10 cats didn't get involved in the mix! I went up on the roof to make sure it wasn't starting to try to build a nest up there, and it was clear. Lord knows WHY it would've wanted to play around up there?!
