I came home the other day to water pouring into the utility room in the basement. After shutting off the water and having to cut a few holes in the wall i found the problem. A copper pipe in the wall had corroded through.
After locating the pipe in the basement and cutting it to cap it off for the night the fitting it was soldered to crumbled in my hand. The copper pipe is paper thin in spots especially around the fittings. This is more than likely from the years of hard and iron loaded water before we put in the softener and iron system 3 years ago.
I guess i need to start changing all the copper in the house as it's only a matter of time before it starts happening else where.
What would be best to replace the copper with? CPVC Flowguard or some kind of Pex. I am leaning towards the flowguard because i have concerns with the metal fittings on the PEx corroding in the future.
I also prefer the Flowguard because it looks neater and seems easier to install, i don't have to buy a pricey crimper.
Your thoughts and Opinions?
Tim
Tim
The whole system is supposed to neutralize the water.
