Been burning in the new BK King for a few weeks now and everything has been going good. I can get longer burn times than I expected with my vent set up.
I've had no issues with draft although my vent setup is "less than ideal". No smoke in the house when starting or reloading, I just open the damper and unlatch the door, wait 3 seconds, and all is good to load.
Vent comes straight about 24" up out of the stove then a 90 into a steel thimble then into the clay lined masonry chimney. Look at my avatar, really the only way to do it. It is an outside chimney off the living room. Has a SS cap and the few small cracks in the crown I have sealed. I know rain is not the issue. I just cleaned the flue and it looked good.
I saw moisture on the outside of the chimney near the bottom underneath where the clay liner starts last week and I just watched it. Well today I opened up the clean out and there is a pool of water there. I don't recall seeing this last year with my old stove.
When I'm burning and the cat is showing active I can at times touch the stove pipe comfortably for a second. I assume condensation is happening and dripping out of the bottom of the clay liner and showing as moisture weeping out of the chimney. The rest of it goes to the bottom.
Typical smoke out of the chimney is a creeping white smoke or nothing at all. Not ideal but not too bad either.
NOW given that I have wood that is barely acceptable this might be the problem. It really is burning fine though. I have Envi blocks but have only been using them on startups as the stove has been burning fine.
I know a liner would be ideal but that is not happening this year.
I'm not sure if I would be answering my own question by saying always use the Envi blocks. I would like some thoughts on exactly how to use them if that's the case.
Thanks in advance!
Thanks in advance!
That's another thing I spent a lotta money on this year!
