nacho said:
			Yes it is the metal insert that appears to be a box within a box. Yes was planning on tearing it out and replacing the whole thing. But not the chimney and flue. The creekstone is about 50 feet high with 2 caps /1 for the basement and one for the living room aprox 6 ft wide. if the info states that an insert is pre fab aproved does it mean that it will work in this situation?
Nacho, if this is a metal fireplace with a metal flue, it is what is called a pre-fab or factory-built fireplace.....
This limits your options.
If you want a built-in stove ....also called a high efficiency fireplace, then you usually have to rip everything out and replace the fireplace AND chimney pipe. This is because your metal chimney is not "generic" and only works in combo with your fireplace.
If you want a retrofit - you can install certain "slip-in" fireplace inserts into it - those that will both fit and are listed for installation into pre-fabs.
Hearth stoves are NOT an option if this is a pre-fab - unless you rip 100% out, install and generic class A chimney, etc.
Funny, but the flues almost look like they are masonry from the picture... but you claim they are metal, and so I am figuring that in on this advice.
