I'm wondering if anyone has had a problem like this - I'm at my wits end! I bought a new Yosemite cast iron woodstove (mahogany finish) in April and had alot of problems with the installation, including water leak at ceiling where chimney was installed. After many, many visits from the installers I was fed up and ended up having a roofer come to fix the leak (there were 2 layers of shingles on the roof - not sure if this could have been a problem with the initial installation?). Anyway, one problem that I'm still having is that there is a brownish-black, sticky substance showing up on the floor, under two of the legs every time I have a good fire going. The installers said they had no idea what it could be and told me to just wipe it up with a cleaner. It's very, very sticky and hard to remove. The stove has a side door and this goopy stuff appears to also be leaking from the bottom of this door onto a ledge under it as well. Has anyone ever had this problem or would you have any idea what it could be?
. Or if you bang two splits together do they go thunk, or have a nice tone to them. Clunk is wet.
