Hello,
I've been enjoying my new Progress Hybrid and have been breaking it in since Friday when we had it installed. A series of small fires, did my best to follow the seasoning procedure.
Tonight I had a bit of a scare, not sure what I did wrong. I caused what seemed like a pretty substantial back puff.
Here's what happened:
I loaded more wood than I've put in it before because it's supposed to drop to the mid-teens tonight, and I wanted it to run all night. So far my burns have been 3-5 hours, but I'm not loading it up anywhere near the top.
Tonight I loaded it up on a bed of coals, let it run for 15 minutes or so, damping it down maybe a third to keep it from heating up too fast. I think I might have engaged the cat a little too soon, I'm not certain.
After I let it run on 1/2 damp with the cat engaged, I dropped it down to 1/4 for a few minutes, then shut it.
The secondaries kicked off for a few minutes, then everything went black for maybe 15, 20 minutes. Then a small event that I'm certain was a back puff occurred. Cat engaged, damper fully closed, stove top was maybe around 500 degrees (meter on the cast iron near the top vent exit).
Everything went back to black, and then a few minutes later a much louder one occurred, and it made the mechanism up near the top, where the cat is, with the three slabs of soapstone on it, jump noticeably and let a wood smoke smell into the room.
I opened the damper a little, which immediately set off the secondaries. Stove temp rose, seems to be hanging around 600. The damper is barely open, just a nudge.
Not sure what I did wrong here, but I'd rather not repeat this performance. I'm guessing I need to check the cat once the burn finishes? I'm worried with the damper open the temp will get into an over-fire range, but it hasn't yet... still staying around 600.
Thanks in advance for your thoughts.
). The Progress Hybrid is an amazing woodstove that will serve your families heating needs for many years. Also, your catalytic combustor should be fine. A back puff should not affect it at all.
