fire_man said:I want to point out that stove clearances are not always measured from an obvious reference point - you have to verify with the manufacturer. There was an earlier post suggesting it should be measured from the glass. For the front of the Progress, its measured from the outside edge of the cast iron trim, but does not include the ash tray.
Thanks for pointing that out, Tony. In my excitement to finally get clearance numbers, I hadn't paid attention to that detail and was of the mindset that it was from the legs.
I have that right now (exactly) for my FV, but with the wider stove if I keep my pipe vertical I lose a couple inches... ug. Add another glitch to my plans... So shielding on the wall? Slant the pipe a bit and shift the stove to the left? The blog post seems to imply they might reduce this after a bit more testing.... I wonder how much more...
