Hi all,
I posted a while back here about my set up. Briefly, I had a Progress Hybrid and new, 25-foot 6" SS uninsulated liner installed inside older clay tiles by some local guys. They didn't get a permit for the install and aren't willing to provide anymore service at this point.
The stove draft is good, but in my opinion not optimal as I will occasionally get a little smoke spill on reloads and backpuffing when stove's turned down very low for overnight burn. I haven't been able to go more than 1-2 weeks without smoke smelling up the house when reloading/overnight burn.
My question is, will an insulated liner make a huge difference in the draft and overall stove performance, given that most of my chimney is INTERNAL? It will be a headache and expensive to get installed because in addition to pulling out the new SS liner, the clay tiles will need to be busted out to get insulation in there. So, wondering if it is even worth it.
Also, if you read my prior post, I tried nearly everything to fix these issues, so am certain this isn't a user error/loading technique problem. I also bought a borescope and the flue is clean straight through.
Thank you in advance for your help!
![[Hearth.com] Progress Hybrid Performance: Should Upgrade to Insulated Liner? [Hearth.com] Progress Hybrid Performance: Should Upgrade to Insulated Liner?](https://www.hearth.com/talk/data/attachments/307/307143-dd859b1ca1ebb646770d9125e96a0e00.jpg?hash=nGdxDI8nha)
![[Hearth.com] Progress Hybrid Performance: Should Upgrade to Insulated Liner? [Hearth.com] Progress Hybrid Performance: Should Upgrade to Insulated Liner?](https://www.hearth.com/talk/data/attachments/307/307157-80a1acda6d6413cf5fde8008c4e656ed.jpg?hash=mU6G1QInZx)
