I think if you start mixing in one or two of your bigger beech splits in your loads you'll see a nice improvement. If you start splitting everything bigger and mix a couple in, maybe you'll have decades of toothpicks instead of just years.
I think the adhesive comes in a small plastic bottle and says "heat safe gasket glue" - that's what I got with my cooktop.
The big calk tube with gray gritty stuff is furnace cement. That stuff is neat, it's soapstone dust mixed with furnace cement and is really sticky.
Quick question about the cement. I bought the PH this past spring, and received the 1st version cooktop later on. Am I supposed to cement the gasket? It's the orginal gasket as it came from the factory, I think it's just held in plase by the cooktop. They didn't send any cement or instructions that said it needed to be cemented in place. Also, is there a reason that they changed the cooktop to have shielding now? Just making sure that I'm not doing something wrong.![]()
No. Mine creacked, stovetop was not over 300s. Not fun when it cracks and splits open 1/4 inch...sounds like a rifle shot. The dog loved it about as much as I did.
No smoke. I lowered the soapstone immediately, so the cast cooktop was concealed. Shut the air completely, let the stove burn down in a low cat burn.So how did the rest of that burn go? i.e. did smoke spill out or anything?
No, not my first use by a long shot. I do all my cooking on the cooktop. Don't be too nervous about using it.Holy smokes! I had no idea it would do that!Was it the first run with the cooktop? I'm a little nervous that mine will do the same. Has this happened to a lot of folks?
Go ahead. It's lots of fun, food cooks beautifully, and you save MORE on power...good old stoves!Thank you for the advice, Rideau. I'll definitely keep those tips in mind. It's pretty much what I do, I haven't used my cooktop for cooking, yet. I was thinking about doing a stew or soup.
My cooktop was cracked as well; however I'm not certain but it may have been cracked when I received it. I had noticed it a few days after installing it the first time I lifted the soapstone to put something on it, there was a big crack staring right at me!
I've replaced the door gasket twice ( on 3rd set now) with no change in the smoke smell. The smoke smell always starts after engaging the draft, and goes away as the fire starts to burn down; I'll guess after 3 hours. I can not determine if it comes from the door or just above it. I wish I could figure it out!
