Progress question
NHJotul
24
New Hampshire
I found out the progress does have a small firebox. It’s rated for up to 2,200 sq feet. So far been using it this shoulder season and it’s been great. Just wondering how often will it need to be loaded come winter?? It’s my only source of heat, so I’d rather not have to load it nonstop.
Curious what kind of burn times I can look forward too, and will it last roughly 10 hours a day on a full load?? As it is, I feel I may need to spit my wood some more, I always used very large ones in the jotul to prevent the catalyst from overheating. 3-4 large spilt being dropped in will fill that much larger firebox.
It depends on a lot of different factors like your layout, insulation, firewood, ect.
How many times did you fill the Jotul? Sounds like you had the F12 top loader? I don’t think that stove had a very good rep. Your PH should be much more efficient.
It may take a bit of trial and error to figure out your new stove but from what I’ve heard you should have no problem going 10+ hours. I have the Fireview and most of the time I’m on a 12 hour burn schedule heating about 1000 sq ft. When it’s colder I may go to an 8 hour schedule. I wouldn’t be surprised if you had a similar schedule with your PH.
Have a good assortment of different sized splits so you can figure out what works best for you. Typically I like to load a larger split or round in the bottom back and fill in from there.
My experience is that fewer, larger pieces in a catalytic stove is best for longer and slower burn (though still hot enough burn). On the coldest days I use the largest pieces and fill in the gaps with a few very small pieces just to get the larger pieces going. Then, I shut it down and let the smoke get burned by the catalytic combustor.
Reactions: Todd
Ohh my setup.
Log home chinked on the inside and outside. Very tight home due to that.
It’s 1,900 sq feet, with a centrally located stove, not open concept. But the stairs are close to the stove so it heats upstairs very well.
Used to keep the living room roasting at 85ish and the upstairs around 75 and I ran that Jotul hot.
My firewood. I cut the trees down a couple years ago, I stacked the full logs with my excavator, then the summer before this current one, I split the wood and stacked it, plus threw a tarp over jt.
It’s mostly ash, with black locus, red, sugar and silver maple, some birch and decent amount of black cherry with a little red oak thrown in the mix that’s easily 3 + years old.
It’s dry dry!! I planned on burning it in the worst design catalyst stove ever made, the jotul F12. I did like the top load feature!! Allowed me to stuff that thing so full I almost couldn’t close the top door a few times.
I got 8-10 and sometimes 12 hour burns. The air control didn’t work so well, it was either open or back puffing / glowing red due to the catalyst. But if brought down slow enough, i could get it to work.
PITA!!
With a burnt out catalyst not working, it struggled to heat the house, but kept the home warm enough. It was livable. Maybe 8 hours at best and a lot of smoke and creosote build up. Took forever scrubbing that chimney, it ran the flew so cold I hardly had a draft. I thought my chimney was poorly designed. No, it was the stove, this progress has no problem getting going without the use of an open ash drawer and tons of newspaper.
Reactions: Todd
How long does it burn for?
Reactions: Todd
From what I’ve seen You should be able to get 12 hours no problem I would imagine on it fully loaded especially with the updated air intake.
Reactions: NHJotul
Actually the updated air intake lets more air in so they could pass the new EPA tests. I don’t know how that will effect burn times but I’m sure it’s not a drastic change and you should easily see 8-12 hours at least.
Reactions: NHJotul
Yes but I thought it was supposed to be very similar to the ideal steel that has bit more low end control from what I read from people saying
Reactions: Todd
Would you leave in the old style one?
Not sure. When I talked to someone at Woodstock if they had the new testing specs they said it hasn’t come in yet but would be posted as soon as they get it. They also said the new test procedure just required more air for the low burn rate to pass so I’m wondering if that will affect the low end numbers?
There is also a big difference in testing with the current crib wood method compared to the old cordwood method so I expect the numbers to be different. For example the Fireview went from a low output of about 8,000 btu per hour low burn with cordwood up to about 10,000 btu with crib wood method but they didn’t have to tweak the air as far as I know.
Kinda wish the PH wasn’t a hybrid and made it a true cat stove. I think it would have a longer burn and lower burn btu output.
Well, I still want to get it due to simplicity and the ability to replicate conditions over and over. The low end for the adjustment handle currently reacts to the lights touch, it’s crazy. But I do like how low I can get the burn. I don’t think I want to lose that. I may try it out and see which I like more.
Reactions: Todd
IIRC, the EPA reported usable capacity of the PH firebox is 2.8 cu ft. Not exactly what I would call small.
Reactions: Woody Stover
It feels small. The door isn’t very big so it’s hard to stuff some large logs in it.
Yes from many reviews I’ve seen it’s hard to pack it full with the door design. Either way you should still be able to get solid 10-12 hour burns out of it putting out solid heat.
12 hours with good coals at the end for a fast restart if I am using big hardwood blocks. If my wood is nicely dry then I can get a nice controlled start to the burn and it ramps up slowly (over the course of a couple hours) to top out at 550 (hard maple/ash) and to 600 degrees (hickory) and then stay there for 2-1/2 hours or so (sometimes close to 3 with hickory). The last 6 hours are basically the coaling stages of the burn as it drops from 400 degrees down to 250 degrees (at about 12 hours). I documented some of my first year or two operation here https://www.hearth.com/talk/threads/new-woodstock-keystone-install.196636/. This year, I am finally back to 3-year dried wood so looking forward to how that improves things even more (the stove was a little fussy on startups but that was because my wood was not really well dried).
The Keystone that I have is probably about half the firebox of the Progress. If I had a Progress, I would probably split my wood 6" on a side (and have some nice rectangular blocks 6" x 6" x length) and if I filled that firebox full I am sure it would last at least 12 hours.
