rjr240
Systems are clear checked yesterday - will try the vinegar trick next opportunity as soon as the weather warms a bit.
Thanks for the tip- rjr
bogydave said:Sorry BK not on your list.
But I'd have lots of Pros & no Cons right now to add, if it were.
BeGreen said:~*~Kathleen~*~ said:~*~Kathleen~*~ said:Blue-black enamel would be dreamy.
Scratch that. I'm going for porcilen!
(broken link removed to http://asheville.craigslist.org/for/2175861642.html)
(SP) teach. That's porcelain, majolica enamel. The blue black is porcelain enamel too, but it is a different process and tougher IMHO. I like the blue black a lot, but that's not a bad price if the stove is in good condition including the cat.
Chargerman said:Side glass is always dirty and really not needed
BrowningBAR said:Vigilant: Throws a ton of heat, but chews through wood like Kirstie Alley at an all-you-can eat Vegas buffet. For the amount of wood I load into the stove I would prefer a longer burn time... by about 2-4 hours.
Intrepid: Sips wood. For as small as it is, when it is burning right, it is remarkable efficient. But it does not throw nearly enough heat, even for it's size.
Heritage: Efficient, not as efficient as the Intrepid (not a fair comparison), but far more efficient than the Vigilant. I love how consistent the temperatures are. I can lock in a temp and it will just stay there for a few hours. Not as powerful as the vigilant, but it does seem to move heat around quite well.
What would be my perfect setup?
Probably three large cat stoves. Ideally it would be something along the lines of either two VC Encores (or an Encore and a Defiant) along with an insert. Right now the only inserts that would fit my format/needs would be a Lopi Declaration or a VC Merrimack. I would prefer a cat insert, but there aren't many out there. But, before I purchase a VC I need to see some long term reports on the three stoves I listed. I would like to see the new Woodstock stove, but clearances are a concern.
Reasons?
-My layout will never allow me to heat with one stove.
-I need longer burn times. During this most recent cold spell stove monitoring is taking up way too much time.
-I need cat stoves for when it is not as cold but still need whole house heating.
-I like it warm. I like it when the whole house is 80. I may not want it to always be 80, but I like to always have that option.
-I need at least two stoves with 8-10 hours of actual heat production. Not burn time. Actual heat production.
Captain Hornet said:I have a old Fisher insert that we have modified with a liner and a big fan. It really works good and puts a lot of heat into the room.
