On another thread Sprinter told me to relate my stove problems so here goes.
I've got a 3 year old Quad 4300 in our un finished house. We're building out of pocket so it's taking me some time, leaving me time to meticulously track heat loss and gain under every conceivable draft setting, wood size and length, etc.
I've burned wood as my primary heat source in several different houses and I've messed with dozens of stoves - my own and other peoples, for over 35 years, and I've only come across one other (Earth Stove), that seemed to magically burn up wood with very little heat produced like my 4300.
I've got mountains of data on the heating performance of this stove but I'm a slow Typer so I'll give you the condensed version. I've got six thermometers around the house and I know exactly how much heat the house will lose for any given int/ext temp diff.
The barrel stove I had in the house during the first year of const. raised the av. house temp approx 50% more / faster than the 4300 with the blower on, which heats WELL OVER 2.2 times as well as it does with the blower off. In other words, the heating effincy of the 4300 with no blower (which I believe the manufacturer states as 65%), is less than 1/3 than a drafty old barrel stove. These comparisons are for the same amount of wood consumed.
I'm burning seasoned spruce (no hardwood available here), which, as I say, is the same wood I've burned for over 35 years, and running stove top temps between 500 and 600, which requires 1/8 to 1/4 draft approx half the time. At that temp, and with the overall house temp at 60, it's only 65 six feet away at 45 degree angle off the front and barely 80 degrees 4 feet in front directly in in line with the blower air.
I've noticed that its extremely hot with the door open, being the only stove I've neede gloves to position wood etc. so I left the door open and that same thermometer immediately went to125 degrees (or more-that pegged the thermometer). Now you'd expect a little more radiant heat without the glass in the way but not THAT much. Then, with the DOOR OPEN, it raised the overall house temp twice as much as with it closed. The house is fairly tight so there's not a lot of draft, you can change that cracking a window but the point is, something is definitely wrong with my setup or the stove itself.
It only stands to reason that a stove with smaller clearance to combustibles puts out less heat out the back and sides, which is definitely the case with this one. In a "seat of the pants" test. you can walk up to most stoves when they're burning well and feel the radiant heat 8 to 10 feet away. With this one it's 5 or 6 feet in front and 2 feet at the sides.
Sorry to be so long winded and I hope I explained things well enough. Thanks in advance for any suggestions.
		 .  I certainly love my PE for its simplicity compared to his.
