We just installed the mentioned stove in our living room, and today was the initial burn. However, once we got it up and running there was some smoke coming out of the front vents, directly under the top plate. Now, when we initially started our fire with kindling and paper, the entire firebox filled with smoke while the chimney heated up. Didn’t have any smoke leaking.
My question to you Quadrafire owners is this: did you notice any smoke leakage when you first used your stoves? My initial thought is that perhaps some of the paint/powder coat on the baffles was just curing and burning off. I’m hoping that’s the case but wanted to reach out to those who’d know. I don’t want to worry about nothing if this is a normal occurance. It seems to be airtight, and I hope I’m right about curing.
Any thoughts? For those who want to know:
25’ chimney with a 6” stainless liner. Inside attached to the stove is a 6” double walled pipe that runs approx 6’ and into the chimney. Draft isn’t an issue. I’ll attempt to post pictures if needed.
Thanks for your time!!
