I decided to switch from wood heat to a pellet stove. I took out the Kuma wood classic in exchange for a 2017 Quadrafire Mt Vernon on Craigslist for $1500. Looks to have not much use. Anyway, I installed it and turned it on, set it to manual.
Start up
SS Low
SS medium
Then Vacuum SW error and it starts to power off.
Does this Every time
So, I bypassed the switch and it works fine.
I took the vacuum switch off and measured ohms. If I very gently suck on the tube....like hard let any suction, the switch turns on and when I very gently blow, the switch turns off. Don’t know if the vacuum switch is bad but it appears to function.
the vacuum tube is clear, the nipple that it connects to on the feed tube is clear.
The gaskets on both the ash pan and the glass door appear to seal very well. Both are very tight.
It’s driving me crazy. I feel like I got snookered by the seller but I’m determined to fix it myself and enjoy not splitting and stacking 6+ cords of wood each year.
How can I fix this vacuum switch problem?
what should I test next? I don’t want to call out a technician if I can help it because that will just defeat the purchase of saving money by purchasing a used stove.
Start up
SS Low
SS medium
