I had my Quadrafire 4100i for 19 years. I burn wood continuously through every cold fall, winter & spring day, consuming about 7 cords of hard wood a year. Every year the thick gauge stainless steel flue liner is cleaned by local Chimney Sweeps. The only maintenance, other than cleaning, was replacing a door seal, replacing the insulating blanket and occasionally replacing cracked / worn fire bricks. A fantastic stove all around...
Then just the other day I couldn’t start a fire, I smoked out my house trying to get kindling to burn and realized I had no draft.
Long - story - short - The problem was the insulating blanket / mat above the firebricks on the top of the burn chamber got vacuum-sucked up against the stove flange connecting to the flue liner and blocked any smoke from rising up & out the chimney.
I disassembled the top section & rotated the blanket / mat around & now it works just fine…
What caused it? I don't know... The proof was a bowl shaped impression when the insulating blanket / mat was removed.
It's a dirty job but somebody had to do it [me} !
Has this happened to you?
