Ok, so everyone seemed so enamored of the Manual igniter position in the Room Temp setting that I decided to try it more extensively than I have in the past.
What I found was that when I did this last night my actual retail stabilized room temperature dropped approximately 3 degrees from the point at which it was maintained in the Auto igniter position and that after the distribution fan went off, although the stove fed minimum pellets and sometimes more as advertised, my distribution fan did not seem to come back on. At all! Ever! All night. Essentially all I had was a single point radiant heat source. Outside temperature dropped to 26f. When in Auto at this temp my distribution fan always comes on and the room temp is maintained far more tightly and higher.
All I did was move the igniter switch from Auto to Manual after the igniter light went out. I touched nothing else. Did I do something wrong? Is this the way others have found it to operate so set up?
I'm the first one to admit that I have very little experience with this setting as I am quite happy with Room Temp Auto but since everyone else seems to think that Room Temp Manual is an excellent operational setting I thought I'd try it.
To be clear, my question is ONLY about distribution fan operation in Room Temp Auto vs Room Temp Manual.
