We have an older Vermont castings resolute stove in our living room. We have a small house about 800 feet on each level. The stove is in the living room which is right where the front door is. At the back of the living room is the stairs to the second level. If you are facing the back of the house the stove is on the right hand exterior wall and there is a doorway into the back of the house on the left hand side of the room. Before going through that door to the back is the staircase to the second level.
The stove used to pull a ton of drafts into the front room and it was very chilly and hard for the room to stay warm. I put up a curtain coming from the back of the house and the room temp has increased drastically. It seems the stove is pulling cold air in from the back of the house which keeps the kitchen and the back of the house cold. I have been reading a little about outside air kits. The stove sits on the hearth outside a fireplace/chimney. There is a pipe in the fireplace that lets outside air in to that, but we have the fireplace blocked off with a piece of sheet metal. Is there a way we could get air to the stove so its not pulling from the back of the house. I think this would allow the back of the house to get a little warmer. Any suggestions would be appreciated
